I have a Remotec ZRC-90, and it has Button Press, Double Press, and Hold 2sec per button. I'd rather have a Toggle Button to where you press once and device on, and press again for device off. I'm guessing it can be done with a script that first determines the status of the device before making the change. I actually found a script that I think is pretty close if not spot on, but I'm not very familiar with Homeseer in general as I just got my unit. Where does it go? What changes does it need?
Sub Main(ByVal theDevice As String) ' Toggle the Specified Device ON/OFF ' DIM is considered ON ' Specify the Device ID as the Parameter Dim devValue As Double ' Get the Device Status devValue = hs.DeviceValue(theDevice) ' Toggle it Select Case devValue Case Is > 0 ' Device ON or DIM, turn it OFF hs.CAPIControlHandler(hs.CAPIGetSingleControl(theDevice,true ,"off",false,true)) Case 0 ' Device OFF, turn it ON hs.CAPIControlHandler(hs.CAPIGetSingleControl(theDevice,true ,"on",false,true)) End Select End Sub
