Jon00 Event Viewer & Documenter for HS3
    #46
    Originally posted by jon00 View Post
    Thanks. At the moment, it just shows the total number of events programmed but that could be changed.
    How about: "Events Filtered: xxx/yyy" ?
    cheeryfool
      #47
      Also, can we get an index number for each row currently displayed, always starting at 1 irrespective of the sort etc? I would suggest putting this to the left of the Run button/Title.
      cheeryfool
        #48
        Jon,
        This is a great script again Was surprised to find some broken events that I seem to have caused myself
        Thanks for sharing!
        Wim
        -- Wim
          #49
          After Jon is satisfied there are no other revisions necessary, the next version will have it:
            #50
            Yes, that has been added. It looked better on the right.
            Jon
              #51
              Originally posted by w.vuyk View Post
              Jon,
              Thanks for sharing!
              Wim
              Many thanks Wim! Appreciated!
              Jon
                #52
                [ATTACH]66014[/ATTACH]
                Randy,
                What browser do you use? I notice that the drop down titles are not fully displayed on your screenshot? It looks correct here on Chrome and Firefox.
                Jon
                  #53
                  Cool. Thanks.
                  cheeryfool
                    #54
                    Randy,
                    It is Chrome. The problem is not in your page, it is in the way Microsoft handles scaling on a Surface Book. The Surface Book has a 3000x2000 pixel display. Microsoft handles the scaling through a percentage, mine is at the default of 200%. Unfortunately it is not a pure scaling as it handles text fonts differently than the rest of the screen and it can be different in header text than body text. . Here is how it looks on a normal desktop:
                    And here is how it looks on the Surface Book at 100%
                    Unfortunately at 100% my old eyes cannot function, so I have to deal with it at 200% and manually resize any screenshots I post. I really like the Surface Book, but I would think they could figure out the scaling to work more consistently.
                    EDIT: I just found a new video driver. Here is is from the Surface Book at 200% then the screenshot is resized to 50%. No change.
                      #55
                      So I just installed it. When it loads, it looks like it's just refreshing over and over and over (As fast as it can). I see you are using a meta refresh, can you add some time before it reloads so that it's not just constantly calling HS ever 20ms or so?
                      Or is this not expected behavior?
                      Edit, I stopped it after a few minutes as it was just constanly refreshing. I only have 236 events. I am on HS3Pro 3.0.0.368 (windows). Do I need a newer version?
                        #56
                        That is not expected behavior. There is some issue with the script accessing your Timers/Counters/Global Variables page.
                        Jon
                          #57
                          Ok, so I didn't have the box "No Password Required for Local/Same Network Login (Web Browser/HSTouch)" and i guess that stopped your script from running. I normally turn this off just in case and I log in each time I visit. It's fine that I need to disable that to run the script. I can just re-enable it when i'm done.
                          You might want to put that in your documents. I didn't see it mentioned.
                            #58
                            Following..
                            Hector
                            Win.2003 OS, HS3
                            MyTrigger,ACRF2,W800,Zwave
                            AP800,Honeywell Stat
                              #59
                              Jon, how deos this compare to your event list viewer?
                              Hector
                              Win.2003 OS, HS3
                                #60
                                Good point, I did not consider that. I'll add this to the docs.
                                Jon
