X10 ERROR (Ti103) "...Argument 'Start' must be greater than zero" [Resolved]
    Pete: thanks for offering to test but a CMA11a will not exhibit this behavior. The plugin uses completely different code to talk to the CM11a & Ti103 interfaces, and this issue is definitely in the Ti103 code.
    Ed: I should have a debug version posted later tonight or tomorrow, thanks for your patience.
    Best regards,
    -Mark-
      @ Mark, ACK; only have CM11A's, TW-523's and Volp's stuff here.
        Hi Ed, I have uploaded a new version to the plugin beta page located here: https://forums.homeseer.com/showthread.php?t=185551
        Please download v.46 and install according to the instructions on that page.
        When it errors again, please post the debug line(s) from the log file. These will look similar to the previous message but with additional info to aid in debugging. It will be helpful to have several of these log entries if they contain different info. If they are all the same then please let me know when you post.
        Best regards,
        -Mark-
          X10 Error
          Just saw this. Downloaded the beta and installed. Will post results. Thank you so very much for your quick response on this.
          Ed
            X10 Error
            Ed
            First Log entry
            Feb-07 11:35:40 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=System.Byte[]: Argument 'Start' must be greater than zero.
              #21
              Thanks Ed, that is very helpful. I have just posted a tweaked variant of version 46. Please install v.46a (in HS3 it will still say v3.0.0.46) and post the erroneous log entry. It will be really helpful if you can post multiple entries so I can know whether the data is the same or different each time it errors. Thanks!
              Best regards,
              -Mark-
                #22
                X10 Error
                Just installed .46a
                Will keep you posted.
                Ed
                  #23
                  X10 Error
                  Just installed .46a
                  Ed
                  Good Morning Mark. So here is the result of 46a
                  Feb-09 2:37:45 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=8, buf=[42-00-00-00-00-00-00-00]: Argument 'Start' must be greater than zero.
                  Feb-09 12:46:26 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                    #24
                    Thanks Ed, these are very helpful! Please post more as they occur so that I can see if there is a pattern. I have an idea of what is wrong but could use more data to be certain.
                    Best regards,
                    -Mark-
                      #25
                      No Problem Thank you for your help.
                      Feb-09 1:08:56 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                      Feb-09 1:05:59 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                        #26
                        X10 Error
                        Feb-09 3:54:20 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                          #27
                          X10 Error
                          Looks like I missed copying this one
                          Feb-09 12:22:37 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=10, buf=[24-3C-32-38-30-30-21-34-42-23]: Argument 'Start' must be greater than zero.
                            #28
                            Feb-09 6:02:08 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              #29
                              X10 Error
                              Quite a bit of activity last night!
                              Feb-09 8:00:18 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              Feb-09 9:51:14 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 12:34:25 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              Feb-09 11:33:33 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              Feb-09 11:32:05 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              Feb-09 11:14:34 PM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=2, buf=[42-23]: Argument 'Start' must be greater than zero.
                              Feb-10 2:46:55 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 4:49:29 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 6:31:22 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 6:03:04 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 6:41:29 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=1, buf=[23]: Argument 'Start' must be greater than zero.
                              Feb-10 6:49:35 AM X10 ERROR Error in Ti103.MSComm1_OnComm() on line 170, c=0, buf.len=8, buf=[42-00-00-00-00-00-00-00]: Argument 'Start' must be greater than zero.
                              Hope something shows up in this.
                              Again, Thanks
                              Ed
                                #30
                                Thanks for the additional log entries, they are most helpful. I just posted v.46b, please install this version and post the resulting log entries.
                                It looks like something may have happened with a recent Windows update and/or the .Net library that is affecting how serial port data is being treated, and this debug version should help give better visibility into what's going on. Unfortunately I cannot get this to fail on my Win10 dev machine so I'll still need your help to continue testing.
                                Best regards,
                                -Mark-
