When I look at the znet device I see multiple USB ports. Can those ports be used to plug in other devices that homeseer can see? For example if I had a sprinkler system whose control box could sit next to a znet, could I use the USB on the ZNET from homerseer (USB port forwarding???).
Does ZNET support USB Ports?
I wouldnt. It's just not worth the headache of something accidentally killing your Z-Wave network.
Raspberry Pis are so cheap, I would get one dedicated to the sprinkler system.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
I agree with Rob on not touching the proprietary ZNet OS on the Homeseer ZNet device.- Pete
IMO, don't do it. I used one of the USB ports to plug in an Aeotec Z-Stick as a secondary controller (I had to plug it in somewhere) and the z-net ended up reseting itself to some weird device that was uncontrollable until @zwolfpack came to the rescue.
See https://forums.homeseer.com/showthread.php?t=190608, which points to the original thread.
If all you had to do was power a motion sensor, then maybe?? since you're just supplying power, not sending or receiving an actual z-wave command.
The Raspberry Pi OS Wheezy or Jessie supports all of the USB ports that are part of the RPi device.
I have my old RPi2 POE connected in the attic using two of the USB ports.
Homeseer can see or utilize any of the USB ports on a RPi.
The ZNET device is a proprietary configured OS on a RPi.
The precaution here is if you are not familiar with Jessie / Linux then there is a chance of messing up the base proprietary ZNET configuration.- Pete
Haven't tried this, but it looks interesting
https://sourceforge.net/projects/usbip/
Available as a Raspbian package via
sudo apt-get install usbip
Another one
http://www.virtualhere.com/usb_server_software
If you are only extending serial ports, there's ser2net (which is what the znet uses so its already installed there).
https://sourceforge.net/projects/ser2net/
or
sudo apt-get install ser2net
To mate up with this on the Windows side, this might work
https://sourceforge.net/projects/com0com/
or this
https://www.eltima.com/products/vspdxp/
I have no desire to use the ZNET as an extender (homeseer support said I could free up a port using a ZNET) I just saw the picture of the znet and wondered if those ports that are just sitting there could be used.
I will probably get a RaspberryPi to mess around with. I don't need the extra ports right away as I'm just getting things ported over to homeseer.
Thanks for the help
I use one of the znet's usb ports for my rfxcom transmitter for my blinds. I leveraged the pre-installed ser2net installation. The rfxcom HS plug-in natively supports rfxcom via tcp/ip.
I have had no issues with running it this way.Len
Linux version: Linux homeseer Ubuntu 16.04 x86_64
Number of Devices: 633
Number of Events: 773
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
3.0.0.48: EasyTrigger
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.0.87: weatherXML
3.0.1.190: Z-Wave
Here repurposed my original RPi2 / Zee 2 device. It is in the attic with a POE connection.
Inside of the RPi is a ZWave dot me GPIO card and PiFace RTC.
It is now a 1-wire temperature / humidity 9097 hub for my second floor using Digitemp and OWFS.
HS3 boxes (2) are reading the digitemp file via a script and updating the HS3 temperature and humidity variables.
Just for the second floor here using old AAG mini (size of my fingernail) combo temperature and humidity sensors purchased in the 1990's.
Been collecting this stuff a long time and have more AAG, Hobby Boards and Midon combo 1-wire sensors.
Ser2net is used for Z-Wave which hardly works at all).
In addition to this stuff installed domoticz on it for the 1-wire sensors / graphs. It is a nice open source automation program. Mostly written using Lua and Python. It is very popular in the EU.
I also downgraded the RPi2 from Jessie to Wheezy because to me Wheezy is faster on the RPi2 than the RPi3.
@Len, are you utilizing both RX/TX RFX com devices?- Pete
Originally posted by Pete View Post@Len, are you utilizing both RX/TX RFX com devices?Len
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.40.0: BLLAN
30.0.0.36: RFXCOM
3.0.6.2: SDJ-Health
3.0.1.190: Z-Wave
Originally posted by madmellow View PostI was curious about the USB ports on the Z-Net. I agree with the advice to not use them...but
It's most interesting that the ports on the Z-Net (power, USB, RJ45, HDMI??, Headphone??) are the same as on a Raspberry PI. I wonder what's inside the box.
