Memory Leak
    Memory Leak
    Hi Guys
    been fighting with a memory leak for months. Installed Jon's plug-in a while ago and it reboots the server when memory gets critical.
    Attached is the handle activity (tab delimited and Pic) over last few days up until this afternoon's reboot
    The server starts off with 1400 handles and goes up continually to 13,000 before a reboot
    I'm running Win 7 Enterprise x64 with 3GB RAM BTW
    I'm on 2.5.0.52 with these plug-ins (all very recent)
    USB-UIRT Interface, BLUPS, HSTouch Server, HSTouch iPhone,
    HSTouch Server Unlimited, PowerTrigger, ZWave Thermostats, AC-RF2 Processor,
    UltraLog, BLStat, HSTouch Android, BLDSC,
    SONOSCONTROLLER
    Any ideas how to track down what's causing it?
    mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    I believe the only way to find the ultimate culprit is to try it one plugin at a time until you recreate the problem.
      From experience, it could be a plugin or a script. The only solution is a process of elimination. Strip down to bare bones, then add one plugin at a time, restarting each time and watch the result. For your scripts, it ought to be easy to determine which absolutely couldn't be a problem, then add the rest a few at a time, keeping track at each restart.
        I personally think it is the base HS pro install and plug-in api that is leaking threads.
        I went down to NO plugins and turned off all events except the jon00's perf mon and threads still rose at a similar rate to what you describe.
        To test it, create a VM and install the base HS in the VM, run the perf mon and watch it run.
        huggy_d1
        Automating made easy
          Huggy,
          Did you downgrade?
          Personally here went back to V.44.
            Same case here. Zero problems with 44. Nothing but trouble beyond that.
              Here now testing with two boxes and two HS licenses distributing the "work" a bit....(testing).
                I too would suggest that the latest builds have a memory leak. I had terrible issues with 50+ builds so reverted back and the problem disappeared.
                Jon
                  I have seen memory (but not handle or thread) leaks in .52 intermittently.
                    Downgrading
                    Originally posted by Pete View Post
                    Huggy,
                    Did you downgrade?
                    I, too, have this memory leak problem with .52. Is there anything special to do, if I were to downgrade to .44?
                    Thanks.
                    "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
                      Easiest way -
                      1 - Backup your entire HS directory.
                      2 - run the update
                      Simple plug n play downgrade.
                        Easiest way -
                        2 - run the update
                        Thank you.
                          This morning noticed this and seeing no errors on any of the HSTouch clients: (I know this error is related to HSTouch server - it still took down HSPro)
                          6/1/2012 8:57:00 AM HSTouch Server Error in GetImage: Exception of type System.OutOfMemoryException was thrown.
                          6/1/2012 8:58:00 AM HSTouch Server Error in GetImage: Exception of type System.OutOfMemoryException was thrown.
                          6/1/2012 9:00:00 AM HSTouch Server Error in GetImage: Exception of type System.OutOfMemoryException was thrown.
                          6/1/2012 9:45:00 AM HSTouch Server Error in GetImage: Exception of type System.OutOfMemoryException was thrown.
                          6/1/2012 10:04:00 AM HSTouch Server Error in GetImage: Exception of type System.OutOfMemoryException was thrown.
                          I let it go until it rebooted itself. The errors are gone now and HS/HSTouch clients are running fine.
                            Easiest way -
                            2 - run the update
                            Will .49 work with .50 HSTouch server?
                            USB UIRT
                            2GIG Thermostat
                            BLUPS
                            UltraLog (SQL2008)
                            Jon00 Plugins
                            Global Cache IP2IR
                            Foscam FI8918W
                              Was Handles not Threads
                              Sorry for misleading you all, that was handles not threads,
                              but threads seem to be growing at same rate (just smaller numbers)
                              USB UIRT
                              2GIG Thermostat
                              BLUPS
                              UltraLog (SQL2008)
                              Jon00 Plugins
                              Global Cache IP2IR
                              Foscam FI8918W
