Playing streaming radio with HS
    Is there a simple way to stream a radio url using HomeSeer using a script or event without buying 3rd party hardware
    sigpic
    A few ideas here: https://forums.homeseer.com/showthread.php?t=187093
    Jon
      Originally posted by jon00 View Post
      Thanks Jon, I looked at your Winamp Controller for HS3 and winamp, thought about and may go down that route. Not sure if winamp can play BBC radio stations though.
      Thanks for responding.
      sigpic
        Of course it can.
        Here is a list of URL's: http://www.suppertime.co.uk/blogmywi...rk-radio-urls/
        Jon
          Of course it can.
          can it be started from an event? ie: use it as an alarm?
          sigpic
            Yes!
            Jon
              Yes!
              Thank you Sir,
              if you charged SOLD
              sigpic
                on, do not know if you can help as my problem is winamp not your plugin, that works perfectly.
                I downloaded the link for Radio Scotland from the web site you suggested
                http://bbcmedia.ic.llnwd.net/stream/...cotlandfm_mf_p and put it into the inifile as so
                [Presets]
                1=Love Songs Florida Plus [URL]http://uk2.internet-radio.com:8143/listen.pls[/URL]
                2=Radio Four   [URL]http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio4fm_mf_p[/URL]
                3=Radio Scotland   [URL]http://bbcmedia.ic.llnwd.net/stream/bbcmedia_scotlandfm_mf_p[/URL]
                [Data]
                Class=Winamp v1.x
                LastVol=255
                However nothing plays., the first preset works
                any ideas?
                thanks
                sigpic
                  Did you use a tab between the radio name and the URL (no spaces) i.e. Radio Four<tab key>http.... ?
                  Did you press the Update presets button on the Winamp Root device (look at the log to see that it has completed)?
                  BTW I added both to my Presets ini file and both worked fine here.
                  Jon
                    Forgot to press update presets Now working perfectly.
                    sigpic
