i think being able to pass audible notifications would be a sweet feature.
Alexa Push Notification
Are you speculating or have you actually seen the API or the feature documented? I will admit that I do not check daily, but to my knowledge as of a month or so ago this was not possible as I did not come across the api.
Maybe I missed it....HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
Originally posted by Krumpy View PostAre you speculating or have you actually seen the API or the feature documented? I will admit that I do not check daily, but to my knowledge as of a month or so ago this was not possible as I did not come across the api.
https://developer.amazon.com/docs/al...-overview.html
You can push notifications to your Alexa with the Notify Me skill (https://amzn.to/2DOsuor). It won't speak your message aloud without prompting, but it does make a "bing" noise and illuminate the LED ring to let you know you have a message.
You can learn more about it at www.notifymyecho.com. The VB script I've successfully used with HS3 running on a RPi3 is as follows (you pass your message as a parameter to the script):
Code:Sub Main(ByVal notification As String) dim accessCode = "[COLOR="Red"]ACCESS_CODE[/COLOR]" dim host = "https://api.notifymyecho.com" dim path = "/v1/NotifyMe?notification="+notification+"&accessCode="+accessCode dim result = hs.GetURL(host, path, TRUE, 443) hs.WriteLog("msg", result) End Sub
Thank you, it worked like a charm.
Originally posted by randyth View PostYou can push notifications to your Alexa with the Notify Me skill (https://amzn.to/2DOsuor). It won't speak your message aloud without prompting, but it does make a "bing" noise and illuminate the LED ring to let you know you have a message.
I'm a little surprised because I expecting to have to modify the script to convert spaces into %20 since the parameter text is being passed as a URL.
Very nice... Thanks for sharing.
Originally posted by randyth View PostYou can learn more about it at www.notifymyecho.com. The VB script I've successfully used with HS3 running on a RPi3 is as follows (you pass your message as a parameter to the script):
~Bill
Originally posted by Bill Brower View PostI'm a little surprised because I expecting to have to modify the script to convert spaces into %20 since the parameter text is being passed as a URL.
Thanks but do you place the script in your script folder or put it in the sub or function part of an event
Originally posted by chiphead View PostThanks but do you place the script in your script folder or put it in the sub or function part of an event
-Randy
