I took out an old Intermatic Z-wave dimmer switch and put in new HS-WD100+, so I can correctly dim new LED lamp (had incandescent before).
Unfortunately, the switch is not working and can't figure out why... Load does not switch on and the LEDs on the face of the switch do not light up at all.
The old Intermatic did not use neutral but I had neutral in the gang box so I pigtailed from there. My current detector shows the live wire is hot. I initially thought I got a bad switch so I ordered a replacement. I put that in and I get the same issue.
Any ideas?
Any ideas?
