I just replaced two Linear/Nortek zwave dimmers with the HS dimmers because the Linear didn't report properly. That part is solved.
The issue is that with the Linear I could dim the BR30 bulbs from 98% down to barely lit. At 1% you had to stare at them for a second to confirm they were actually on; and they were.
With the WD-100+ the bulbs will not dim less than 5%. There is no difference between 5% and 1% and unfortunately, that's too bright for our preferences. I realize some bulbs do not dim down as far as others, but here the issue is the dimmer, not the bulbs. There are two dimmers side by side and they behave the same.
Finally, when dimming from full bright down, I cannot see a difference until I drop below 50%. So basically, half the scale is useless and they don't go down to 1%.
Is there any setting I can apply that would adjust this? The FW is 5.17.
