Hey Larry,
Hope all is well. So I moved into virtual and am trying to fix nuisances and get hstouch screens deployed - and running into issues with speaker control.
Can control with on/off button in web ui, but cant see status in the status column. cant control in an event using the device value change on/off (just shows blank after you select on or off). And also get the log errors that have been reported in other threads.
Suspect status is related to the errors we're seeing. ouside of array, and status property has been depreciated - prob a simple code update to use a different call. Could you take a look? Havent seen many updates on here in a while. You may not be actively working on this plugin anymore, but if you could just do a quick update to fix those issues, it would help a ton of us out.
Toby
6/15/2012 5:56:50 PM Plug-In Initializing Plug-in: AB8SS on COM port 5
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-1 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-2 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-3 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-4 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-5 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-6 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-7 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Speaker-8 was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS Input A/B was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM Warning 'status' property on device AB8SS All Speakers was accessed - this property has been deprecated and should not be used.
6/15/2012 5:56:50 PM AB8SS Info ComPort is Initializing....
6/15/2012 5:56:51 PM UltraM1G Warning No response/improper response from Elk M1 to command 'lw00'
6/15/2012 5:56:53 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st01600'
6/15/2012 5:56:54 PM AB8SS Info COM5: Opened Successfully.
6/15/2012 5:56:56 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st01600'
6/15/2012 5:56:58 PM iTunes Library loading completed.
6/15/2012 5:56:59 PM Error Initializing interface: AB8SS-Index was outside the bounds of the array.
Toby
