Hello-
Using examples on this forum, I am testing a simple script that counts the number of devices in a certain state. The script works fine however it appears that a variable (NumberOfOnDevices) is persisting between individual script runs. This does not make any sense to me. Can anyone shed any light on how this variable is being incremented instead of being created new on every run of the script?
Here is the script:
Here are the log entries:
Jun-28 11:27:04 AM Event Running script and waiting: /usr/local/HomeSeer/scripts/CountWindowOpen.vb
Jun-28 11:27:04 AM Event Event Trigger "WHF Check for Open Windows"
Jun-28 11:27:04 AM Event Event WHF Check for Open Windows triggered by the event page 'Run' button.
Jun-28 11:23:53 AM OnCount I Count 20 as open
Jun-28 11:23:53 AM Event Running script and waiting: /usr/local/HomeSeer/scripts/CountWindowOpen.vb
Jun-28 11:23:53 AM Event Event Trigger "WHF Check for Open Windows"
Jun-28 11:23:53 AM Event Event WHF Check for Open Windows triggered by the event page 'Run' button.
Jun-28 11:22:07 AM OnCount I Count 16 as open
Jun-28 11:22:07 AM Event Running script and waiting: /usr/local/HomeSeer/scripts/CountWindowOpen.vb
Jun-28 11:22:07 AM Event Event Trigger "WHF Check for Open Windows"
Jun-28 11:22:07 AM Event Event WHF Check for Open Windows triggered by the event page 'Run' button.
Jun-28 11:21:34 AM OnCount I Count 12 as open
Jun-28 11:21:34 AM Event Running script and waiting: /usr/local/HomeSeer/scripts/CountWindowOpen.vb
Jun-28 11:21:34 AM Event Event Trigger "WHF Check for Open Windows"
Jun-28 11:21:34 AM Event Event WHF Check for Open Windows triggered by the event page 'Run' button.
Jun-28 11:21:13 AM OnCount I Count 8 as open
Jun-28 11:21:13 AM Event Running script and waiting: /usr/local/HomeSeer/scripts/CountWindowOpen.vb
Jun-28 11:21:13 AM Event Event Trigger "WHF Check for Open Windows"
Jun-28 11:21:13 AM Event Event WHF Check for Open Windows triggered by the event page 'Run' button.
Jun-28 11:20:58 AM OnCount I Count 4 as open
Howie
Here is the script:
Dim DeviceList() As Integer = {167, 168, 169, 170, 171, 172} Dim CurrentStatus As CAPIStatus Dim NumberOfOnDevices As Integer = 0 Sub Main(Parm As Object) For Each DevRef As Integer In DeviceList CurrentStatus = hs.CAPIGetStatus(DevRef) If CurrentStatus.Status.ToLower = "violated" Then NumberOfOnDevices += 1 Next hs.writelog("OnCount", "I Count " & NumberOfOnDevices & " as open") End Sub
Howie
