BLNinjaControl (3P) Discussion of BLNinjaControl plug-in |
December 22nd, 2016, 07:36 PM
Seer
Plugin for CM19A
BLNinjaControl is not visible in list of Plugins in HS3 ZEE S2 Edition 3.0.0.297. I thought I saw it in a previous version. What I am really looking for is a plugin for CM19A. I read the forums and it sounds like lots of past issues, but where are we now? Is BLNinjaControl or BLRF the right plugin, and will it work? Simple X10 On and Off from Hometroller Zee S2 to various X10 receivers throughout home. CM19A works fine on my PC with Firecracker App.
December 22nd, 2016, 08:06 PM
OverSeer
The active home sdk will only work on Windows
December 24th, 2016, 03:23 PM
Seer
Not using ActiveHome, just wanted to use CM19A with Zee2. Is this possible?
Thank you !!
December 24th, 2016, 08:40 PM
HomeSeer Technologies
Quote:
Thank you !!
Not supported. The CM15a is your best bet.
Thread Tools |
Display Modes |
Linear Mode
HTML code is Off
