I have RC-80 thermostats (I think), I am running HS2 and I have version .16 of the HAI thermostat plugin. Fairly frequently - perhaps two or three times per month - the plugin seems to freeze, and it will not update the actual temperature in Homeseer. I'm starting to test what actions will reset the plugin to pick up the actual temperaturs again - of course, restarting Homeseer will do it, and it seems that perhaps changing the polling interval does it as well (I have to retest this).
The problem seems to afflict all five thermostats, rather than any one particular one.
Any ideas what could be causing this? And a secondary question - are there any scripting commands available to control the plugin? To fix this problem, I'd be willing to adjust the polling interval every hour as a way to "prod" the plugin to keep alert.
Thanks in advance for any help you can provide.
