Originally posted by Fuddy
View Post
New user needs help.....
Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Just checking thru the event and the trigger is suppose to be "Simulation start". The question to ask is who or what emmits the Simulation start trigger?Hector
Win.2003 OS, HS3
Originally posted by Fuddy View PostThen I set up the sim times in the Options screen.Hector
Win.2003 OS, HS3
Originally posted by Blade View PostYou want to use the event actions, not triggersHector
Win.2003 OS, HS3
Hector:
If you look at the events I posted above, the heading on each section labels each part of the event, same as on your system.Marty
I tried to explain the difference above, but I guess I didn't.
The bloccupied event triggers will trigger events based on the sim starting or stopping.
The bloccupied event actions will start or stop the sim - sort of like enabling or disabling the plugin. As Bob said, you need a couple of events to do this.
The times in the option screen define the window when the sim will turn the lights on and off, if the sim is started. The on/off activity will vary randomly according to how it's set up in the options screen.
Regards
MichaelRegards,
Michael
HS3, W10 Home, HSTouch, W800, Z-Stick+
This used to work for me but now has stopped!
I'm running HS3 on Server 2012.
If I start the sim from an event, the log says BLOccupied Info Occupancy Simulation has been started!
When I stop it, BLOccupied Info Occupancy Simulation has been stopped!
However none of the devices ticked in options come on. I have ticked debug, but where is the debug log saved?
Nothing is appearing in the main HS3 log other than the references above.
Cheers
CheersHector
Win.2003 OS, HS3
Any updates on this? This plugin has stopped working for me too, on HS3.HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
