Some user report that , sometime will happen a error on the PLCBUS network and it cannot send out the PLCBUS command via Homeseer.
And it will occur following error message in Homeseer Log :
PLCBUS error Too long wait for interface respond to command.
(see attachment)
After discuss with manufacturer's R&D , it found that , most likely is the noise problem. If there have a noise problem on the powerline , then PLCBUS chipset cannot send out PLCBUS command. Once homeseer issue a command to controller , if it cannot send out the command , it will not feedback to computer and it will occur this error message.
For this problem , you need to add a Noise Absorber and connect with your PLCBUS computer interface. After add this noise absorber , most of user'
s problem solve immediately.
http://x10-hk.com/store/product_info...roducts_id=276
(see attachment)
