On my system, this script would display "This is line 1" and "Sunny" on my Area 1 keypads.
Note: "$$DSA:Station1-todays-short-prediction-day:" is a replacement variable. Station1-todays-short-prediction-day is available via UltraWeatherBug3 HSPI.
Ultrajones
sub Main(parm as object) Try Dim KeypadArea as Byte = 1 ' 1 though 8 Dim KeypadAction as Byte = 1 ' 0=clear message, 1=clear message with * key, 2=display message until time-out Dim BeepKeypad as Byte = 0 ' 1=beep, 0=no beep Dim DisplayTimeout as Integer = 0 ' 0-65535 in seconds Dim Line1 as String = "This is line 1" Dim Line2 as String = "$$DSA:Station1-todays-short-prediction-day:" hs.PluginFunction("UltraM1G3", "", "DisplayTextOnLCD", New Object() {KeypadArea, KeypadAction, BeepKeypad, DisplayTimeout, Line1, Line2}) Catch pEx As Exception ' ' Process program exception ' End Try End Sub
Ultrajones
