Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Hardware > Z-NET
Z-NET Discussions about HomeSeer's Z-NET IP-Enabled Z-Wave Interface
Old May 2nd, 2015, 12:16 PM
Ricky Ricky is offline
Need to re-install znets
I have two znets with about 50 devices each. My router went down and after installing a new router there is a mixup in the ip addresses on my znets.
Question. If I need to re-install the znets, will all my devices be intact and events still run, or do I have to re-install everything?
Sent from my iPad using Tapatalk HD
Old May 2nd, 2015, 03:25 PM
rprade's Avatar
rprade rprade is online now
Since the node information is stored in the Z-Net, I would think all you need to do is edit the controller page IP addresses to match the new IP addresses assigned to the Z-Nets, or assign the old addresses via static IP in the Z-Net, or change to the configuration where HomeSeer finds the Z-Net by name. None of those should cause you to lose any devices or break any events.
Randy Prade
Aurora, CO
Prades.net
"Do or do not, there is no try"
-Yoda
Old May 2nd, 2015, 04:33 PM
Right, I have been doing that. My question concerns, what if I was to remove a znet and then add it again. What happens to all the devices stored in the znet and events using them. I realize the devices are stored in the znet, but what happens on the HS3 side when I remove a znet and add it again? Is my question clear?
Old May 2nd, 2015, 04:46 PM
rprade's Avatar
I guess, I don't understand what you mean by "remove". If you mean remove the controller from the HomeSeer controller configuration page, then add it again, it should still work the same. You can always take a backup of the controllers before you do anything, then restore each Z-Net from its backup after you have added them back to HomeSeer -only- if you loose devices. You would only have to fully optimize the network again. A backup of all controllers and of HomeSeer is a good idea before you do anything with them.
If you are removing a controller from the configuration page, then adding it in at a new address or with a new name, but not changing the Z-Wave device table within it, it should match back up to the devices in HomeSeer.
Only 4 Znets left in the HS store! Automated Z-NET 5 March 30th, 2015 04:38 PM
Trying to install .41 Eug ISY Plug-in Beta (3P) 8 July 3rd, 2009 01:40 PM
Which AV should I install? Rotech HomeSeer General Discussion Area 15 February 1st, 2008 05:24 PM
Homeseer 2.x install dependant in Homeseer 1.x install KLS HS2 / HSPRO 15 November 13th, 2006 12:45 AM
~!~HSTV VR install error~!~install error,Sorry no data found Krumpy HSTV 3 June 28th, 2003 08:52 AM
