Plugin support
    Plugin support
    The IP thermostat plug-in is based on a supported and non-supported API's. I
    So be aware of every firmware or web site update, it might prevent the plugin from accessing the thermostat or any other issues.
    If a firmware or website update breaks the plugin, I will try and fix this as soon as possible. But I cannot make any promises of how fast it will be solved or even in the worst case scenario it cannot be solved at all.
    Still this plugin has been flawlessly working for 2 years and for hundreds of users
    Thank you for understanding.
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
