Fibaro Dimmer 2 & Scenes
    Does the Fibaro Dimmer 2 work with Scenes?
    I can't get it working but don't know if that's because it doesn't work - or if I'm doing it incorrectly as I've not setup scenes before.
    I can setup a scene in Homeseer and give it a name - that works. I've enabled scenes on the Dimmer two but I can't see any way of triggering the scene? Am I missing an important part of config that links the two?
    thanks
    thanks
    I have never gotten this to work, and I have received no helpful feedback from support.
    But, i truly miss this functionality. And I would appreciate some official feedback.
      I would also like this to work.
      I work as an electrician and have installed hundreds of Fibaro devices.
      And was testing Homeseer to see if i could migrate some customers but if this dont work it will be impossible as i use switch 2 for scene activasion alot.
      Has anyone got this to work?
        I get the feeling that scenes are somewhat depreciated.
        I've never used fibaro products. But I can tell you about my experience with my cooper 5 button scene controller.
        To set up each button/add a scene I clicked the name of the scene/button in question on my device management list and went to the zwave tab.
        From there I expanded the settings section.
        Then I used the drop down list to pick a device, clicked the 'add' button to it's right; that moved it into the pane above it.
        in the pane just above the drop down list, next to the device I just picked, I picked the command I wanted. finally I hit 'save scene changes'
        Here is an example where I added 4 devices to a button. These devices are dimmers so I set the scene level ramp rate to 3 seconds to match my other lighting.
        HS4 Pro on Shuttle NC10U, Win10; Z-NET
        Number of Devices: 1005
        Number of Events: 293
        Plug-Ins: BLLock, DirecTv, EasyTrigger, Honeywell WiFi Thermostat, Marquis monoprice Amp, MeiHarmonyHub, PHLocation2, Pushover 3P, UltraM1G3, rnbWeather, Worx Landroid, Z-Wave
        External applications: Homebridge-homeseer, Geofency, EgiGeoZone.
          That looks great the problem is that i dont have that settings
            But when pressing the second button i get this in the log
            Z-Wave ApplicationCommandHandler from node 4 HANDLING: COMMAND_CLASS_SCENE_ACTIVATION Frame(7)=1
              That way requires specific support for the hardware to be implemented by Homeseer.
              Scenes is a standard across all zwave products. And any reason as to why central scenes is implemented in such a subpar way in HS3 escapes me.
                Couple more thoughts based on the replies. 1) ensure you're using the child device and not the parent when you check the settings. 2) ensure the device has been added correctly using homeseer's add node function, you could try the Audit this node button, and/or Rescan. If you still have no child devices and settings doesn't populate, you may have to dig into the Associations and add them there.
                Another thought, I saw this thread where they discussed adding a fibaro product using the Add Node Unsecure, you may wish to try that as well
                https://forums.homeseer.com/showthread.php?t=182929
                Homeseer can create/modify scenes which may also be helpful when setting up the associations. Plugins > Zwave > Scene Management
                I found an old HS2 help file on the page, it's not changed that much with HS3
                http://homeseer.com/support/homeseer...ave_scenes.htm
                I also found a rather interesting post in the forums
                https://forums.homeseer.com/showthread.php?t=138177
                Even though it would appear that using associations to set up a controller is frowned upon, if it works it works. Some combination of creating the scene under scene management then associating it may be the key
                If you do get things up and running, don't forget to let us know
                  Homeseer and fibaro scene controllers
                  Is homeseer planning to implement this functionality?
                    Fibaro dimmer 2 scenes not working
                    I'd really like to see HS3 support scenes with the Fibaro dimmer 2 as well.
                      beta z-wave
                      I've heard back from support with some good news on this...
                      "Z-Wave update 3.0.1.154 just went live in the beta section, it includes added features for the Fibaro products that add more user-friendly support for scenes. I have not yet tested the update but it is available for everyone if you would like to give it a try. As of this update, no further work will be done for to the Fibaro dimmer 2 and switch 2."
                      Details here of the beta: https://forums.homeseer.com/showthread.php?t=175414
                      I've never tried the beta plugins.. do I simply disable the main Z-wave plugin and install the Beta? Will it maintain all of my devices and z-wave settings?
                        Yes. And yes.
                        But it is ALWAYS a good idea to back up your Z-wave controller AND the entire HS3 folder before you install beta updates (or any update).
                          Originally posted by Moskus View Post
                          Yes. And yes.
                          Great that Homeseer implement this functionality.
                          Do I also need to delete and add the dimmer again?
                          I give it a try tonight, but I cant see in the log that a scene command is sent by the dimmer. I changed the parameter 28 to 1, but still no scene commands in the log.
                          I did a 'rescan' on the Fibaro dimmer2. Also no luck.
                          Did I miss something? Or how can I activate this funtionality?
                          thanks in advance.
                            Keen to understand how we enable scene control from Dimmer 2 modules. I've looked through the forums and found a few questions asking the same thing but no answers!
                            I'm using release 3.0.1.159 (so after scene functionality was added) and have excluded and re-added nodes, non secure and secure. Enabled scene control with dimmer 2 (parameters 28 to 1).
                            I don't see any way to control a scene at the end of this. Any ideas?!
                              +1 here...
                              Would really like to make use of Scenes so I can reduce the huge number of lighting control events I have, but I can't find a way to trigger a scene from HomeSeer. Would it be possible to add a ZWave Event Action, or even a script function (via CAPI would be fine), so that we can trigger scenes without necessarily pressing a button on a scene controller?
                              Cheers,
                              Jon.
