The following is repeated in the log.
Any ideas to solve this would be welcome.
-Philip
Feb-06 4:13:15 PM Informational Elk Real Time Clock reports: 06/02/2017 16:13:14, dd/mm format, 24 hour format, DST is Active
Feb-06 4:13:15 PM Error Data that caused error in ProcessCommand() subroutine: Len=19, Cmd=KC, Data=0000000001000000000, Reserved=00
Feb-06 4:13:15 PM 1 Error System.NullReferenceException: Object variable or With block variable not set. at Microsoft.VisualBasic.CompilerServices.Symbols.Container..ct or(Object Instance) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.Object LateIndexSetComplex(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean OptimisticSet, Boolean RValueBase) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateIn dexSetComplex(Object Instance, Object[] Arguments, String[] ArgumentNames, Boolean OptimisticSet, Boolean RValueBase) at HSPI_ULTRAM1G3.hspi_plugin.ProcessCommand(String strLen, String strCmd, String strData, String strReserved)
-Philip
