Hi all, just installed HS3 Pro a few days ago along with the Zwave SmartStick +... we have a lot of Zwave devices and want to make sure I'm installing and setting HS3 up the correct way so we dont have to go back and change everything.
Looking at the Youtube videos and images and so on, I'm a bit confused on how to setup the way the new devices (nodes) come into the system.
Already went to Tools>Setup>Custom>Location 2 Label and changed that to Category.
I go to Plug-ins>Zwave>Controller Management>SmartStick+>Actions>Add/Include a Node> I then add the device and it installs into the system.
I then go to Home and the device entered an array of items. The categories say a "Node 3"(then Node 4 and so on) and the Rooms say Zwave.
Should I select all the items it created and bulk change the Category and Room names to the correct locations? i.e. Category: Lights, Room: Kitchen? Or what is the best way to do this because in the videos all the items that a device brings into the system are different.
I'm going to be using HSTouch to design the system and Alexa to control as well if that makes a difference. Thanks all!
