BLLED is in development
HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
That will be great just in time for me to receive my beta brites LOLHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by kenrad View PostBlade,
just a quick question I started looking at your plugin and it looks to me like there is a option for an ethernet connection is this something that could be connected to a global cache device??
Cheers Ken
Steve
Help with example script
I tried setting the time and always received an error. I setup the serial port.
"Jun-06 11:39:00 PM Event Error Event action Run Script could not be completed - action does not have a valid script file or immediate command."
This was my Event. I would appreciate any help and suggestions and examples.
Cheers,
Gary
It would be cool if users that are fairly proficient in scripting could post some scripts for BLLED to help some of us non compturer guys out getting started. I would like a way to send caller ID info from HSPHONE to the signs and not sure how to accomplish that also possible have scripts that would display the temp or humidity from some of my zwave multi sensors but I'm not event sure where to start
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
I have posted 1.0.8 to the HS3 updater
- You can now perform all event actions and scripting calls for all signs. See the help for scripting calls.
- Have attempted to add USB support for the Prism - not tested
- You can set the date/time on the sign or all signs with event action or scripting call
- You can reset (hard or soft) or clear the memory for a sign or all signs using event action or scripting
I have posted 1.0.10 to the HS3 updater
- Added a SetPicture scripting call that will allow you to set a picture on the sign from a bitmap file (see the help web page for details)
Here is an sample:
Code:hs.PluginFunction("BLLED", "", "SetPicture", New Object(){1, "A", "C:\music_note.bmp"}) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "A", "{callpic=A}{callpic=A}{callpic=A}"})
I have attached the sample music note bitmap that I made to test this.Attached Files
Originally posted by sparkman View PostHi Bob, received the BetaBrites today and I've been playing with the plugin and so far everything is working great.
Thanks for creating the plugin and sourcing the BetaBrites!
Cheers
Al
