Arduino Plugin V1.0.0.36.
    Originally posted by Jakob.Sand View Post
    Hej Greg,
    What verision of Arduino Sketch program is supported and recormened for MEGA Arduino boards? 1.0.6 ?
    Per Greig: "Ethernet will not work with the 1.0.6 version of the Arduino ide. Can you download V 1.5.6-R2 and update the library's with the ones on the config page". That version works fine with my Mega 2560r3 boards. It also works fine with the UNO boards. I have also had much more reliable connectivity with genuine Arduino Ethernet shields than the Wiznet clones.
      Hi Greig
      I am new to Arduino and got it working with an Ethernet Shield. Nice plug in thank you.
      I want to setup a second board. I have a mega 2560 with a wifi shield. Do you have a sketch written for a wifi shield to replace the Ethernet sketch you could share with me?
      Will
        Originally posted by will40 View Post
        Hi Greig
        Will
        Hi Will,
        Sorry but I do not have a WiFi shield as when I looked at them I found them to be very expensive for what they did. I have it on my list of thing to do to get some kind of wireless device working with this.
        I know there are users using the Ethernet shield and a WiFi games adaptor that works but I seem to remember them saying that the connection drops out every now and then.
        Greig.
        Sent from my HTC One using Tapatalk
        Scripts =
        Various
          Originally posted by enigmatheatre View Post
          Hi Will,
          Greig.
          Hello Greig
          Have you given any more thought to the wireless shield? I would be willing to mail you a wifi shield to help with your development.
          Will
            Hello Greig
            Will
            This is higher up the list of things to do but not at the top. I have a list of things to order and it is on there. I also have a beta tester who has helped modify my code to work with the WiFi shield but there would be a lot of code changes and I am running out of space on the boards with all the libraries and I have to pick what is best for all. I am looking in to other wireless solutions to but again this will take some time to do.
            Greig.
            Scripts =
            Various
              #21
              I know it says there is an api for sending custom values but where can I see the information on how to do this? I would like to send the ph and orp of my pool thru serially connected atlas scientific stamps. Want to make sure this isn't past my level of knowledge before I purchase everything.
                #22
                Arduino Setup not building
                Anyone have the issue of adding a new board and the setup screen not being built? I have added board #3 and it adds the board, but the setup drop down never populates. I have tried removing it and adding it again and still no luck, my first board seems to be the only one that populates consistently.
                Any feedback would be appreciated.
                  #23
                  What version of the plug-in are you running?
                    #24
                    Should be the current version 1.0.0.36
                      #25
                      My computer is a bit slower and started having the same issue once i added several boards
                      What i have to do is disable all the other plugins and restart homeseer then open it up and make the changes i want then enable all the other plugins again
                        #26
                        You might want to try v1.0.0.103. It is in the BETA section at the bottom of the plug-in management page. There have been a lot of changes since 1.0.0.36 that improve board connection and configuration.
                          #27
                          I tried the Beta plug in and that fixed the issue! Thanks for the advise, I did not think to look to see if Greig had loaded a new beta.
                            #28
                            Input issues on Beta
                            Running the Beta version - My input is not updating as expected. I can trigger the input and I see it change (open contact) so 0 volts. I can then close the contact and I show 3.7volt approx on the input yet I have to reset the arduino to get the update. Anyone else seeing this?
                              #29
                              If this is an analog input, I know there have been some others reporting anomalies. Unfortunately, I do not use analog inputs, so I really cannot help much. If I get some time later this week, I can try on my test board.
                                #30
                                Sorry, this is a Digital input - The voltage reading was taken with my volt meter.
