Bob,
I notice that the plugin very often looses the connection to the Roomba here.
If the plugin is running for more then a day chances are almost 100% that a trigger to start the Roomba will not start the roomba itself. A restart of the plugin is then needed to get it started - if I am lucky.
Even the restart of the plugin does not always connect to the roomba it seems, but without the plugin noticing it is not connected? Here are two logs of a restart in the plugin:
A restart, correctly connecting:
An incomplete restart done just before the above log, no errors, but no info on failed connection, nor a status to warn me.
Is it possible to have the plugin to show if it is or is not correctly connected to the roomba? Because it is now a bit hit or miss starting the roomba unattended...
Wim
nov-15 17:31:09 BLRoombaWifi Roomba: Robbie - weekly schedule changed to No schedule entered nov-15 17:31:09 BLRoombaWifi Roomba: Robbie - software updated to v2.2.11-4 nov-15 17:31:09 BLRoombaWifi Roomba: Robbie - timezone changed to Europe/Amsterdam nov-15 17:31:02 BLRoombaWifi Roomba: Robbie - language changed to nl-NL nov-15 17:31:02 BLRoombaWifi Roomba: Robbie - country changed to US nov-15 17:30:56 Plug-In Finished initializing plug-in BLRoombaWifi nov-15 17:30:56 BLRoombaWifi start BLRoombaWifi plug-in has been initialized nov-15 17:30:55 BLRoombaWifi start Roombas have been loaded. nov-15 17:30:54 BLRoombaWifi start Loaded configuration successfully nov-15 17:30:54 BLRoombaWifi start BLRoombaWifi version is: 2.0.12.0 nov-15 17:30:54 BLRoombaWifi start Initializing BLRoombaWifi... nov-15 17:30:54 Info Plugin BLRoombaWifi has connected. IP:127.0.0.1:54628 nov-15 17:30:46 Info Plugin BLRoombaWifi with instance: has disconnected nov-15 17:30:43 Plug-In Shutting down Plug-In: BLRoombaWifi
nov-15 17:28:24 Plug-In Finished initializing plug-in BLRoombaWifi nov-15 17:28:24 BLRoombaWifi start BLRoombaWifi plug-in has been initialized nov-15 17:28:23 BLRoombaWifi start Roombas have been loaded. nov-15 17:28:22 BLRoombaWifi start Loaded configuration successfully nov-15 17:28:19 BLRoombaWifi start BLRoombaWifi version is: 2.0.12.0 nov-15 17:28:19 BLRoombaWifi start Initializing BLRoombaWifi... nov-15 17:28:19 Info Plugin BLRoombaWifi has connected. IP:127.0.0.1:54552
Wim
