ultram1g continually disconnects
    hey! I'm having issues with this plugin disconnecting from my elk m1. I'm running HS on linux and connecting to the elk via the m1xep. I really can't seem to find a pattern as to when it disconnects, seems to be arbitrary and the logs don't help a lot either...
    Apr-01 3:30:41 AM	 	Plug-In	Finished initializing plug-in UltraM1G3
    Apr-01 3:30:41 AM	 	Informational	UltraM1G3 version 3.0.6616.28548 initialization complete.
    Apr-01 3:30:41 AM	 	Info	Plugin UltraM1G3 has connected. IP:127.0.0.1:51952
    Apr-01 3:30:40 AM	 	Plug-In	Found plug-in: UltraM1G3, version: 3.0.6616.28548
    Apr-01 3:30:08 AM	 	Info	Plugin UltraM1G3 with instance: has disconnected
    Apr-01 3:30:08 AM	1	Error	System.NullReferenceException: Object reference not set to an instance of an object at HSPI_ULTRAM1G3.hspi_plugin.ShutdownIO () <0x41e67750 + 0x0004f> in :0
    Apr-01 3:30:08 AM	 	Shutdown	Shutting down plug-in: UltraM1G3
    Mar-31 8:44:42 PM	 	Plug-In	Finished initializing plug-in UltraM1G3
    Mar-31 8:44:42 PM	 	Informational	UltraM1G3 version 3.0.6616.28548 initialization complete.
    Mar-31 8:44:42 PM	 	Info	Plugin UltraM1G3 has connected. IP:127.0.0.1:39238
    Mar-31 8:44:41 PM	 	Plug-In	Found plug-in: UltraM1G3, version: 3.0.6616.28548
    Mar-31 8:44:14 PM	 	Info	Plugin UltraM1G3 with instance: has disconnected
    Mar-31 8:44:14 PM	 	Shutdown	Shutting down plug-in: UltraM1G3
    Thoughts?
    may have found a hint in the logs as to what is going on. I noticed the system disconnected just a bit ago, and I was digging into it a little
    Apr-08 12:53:55 PM	 	Warning	No response/improper response from Elk M1 to command 'cv0200'
    Apr-08 12:53:54 PM	 	Warning	Invalid RegExp for data CV020004
    Apr-08 12:53:54 PM	 	Warning	No response/improper response from Elk M1 to command 'cv0200'
    Apr-08 12:53:52 PM	 	Warning	No response/improper response from Elk M1 to command 'cv0100'
    Apr-08 12:53:51 PM	1	Error	System.FormatException: Additional unparsable characters are at the end of the string. at System.ParseNumbers.StringToInt (System.String value, Int32 fromBase, Int32 flags, System.Int32* parsePos) <0x7fbeb51479a0 + 0x00425> in :0 at System.ParseNumbers.StringToInt (System.String value, Int32 fromBase, Int32 flags) <0x7fbeb5147970 + 0x00028> in :0 at System.Convert.ToInt32 (System.String value, Int32 fromBase) <0x7fbeb4f5fe00 + 0x00039> in :0 at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived (System.String strDataRec) <0x4119ceb0 + 0x00310> in :0
    Apr-08 12:53:51 PM	 	Warning	No response/improper response from Elk M1 to command 'cv0100'
    Apr-08 12:53:49 PM	 	Warning	Invalid RegExp for data CM0000 0C100042
    Apr-08 12:53:37 PM	1	Error	System.FormatException: Could not find any parsable digits. at System.ParseNumbers.StringToInt (System.String value, Int32 fromBase, Int32 flags, System.Int32* parsePos) <0x7fbeb51479a0 + 0x00446> in :0 at System.ParseNumbers.StringToInt (System.String value, Int32 fromBase, Int32 flags) <0x7fbeb5147970 + 0x00028> in :0 at System.Convert.ToInt32 (System.String value, Int32 fromBase) <0x7fbeb4f5fe00 + 0x00039> in :0 at HSPI_ULTRAM1G3.hspi_plugin.ProcessReceived (System.String strDataRec) <0x4119ceb0 + 0x00310> in :0
    Apr-08 12:53:19 PM	 	Warning	No response/improper response from Elk M1 to command 'az00'
    Apr-08 12:53:18 PM	 	Warning	Invalid RegExp for data 00000000000800000000000000000000000000000008000000000000000000000006000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000B
    Apr-08 12:53:18 PM	 	Warning	No response/improper response from Elk M1 to command 'az00'
    Apr-08 12:53:16 PM	 	Warning	Raw data was: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000008B
    Apr-08 12:53:16 PM	 	Warning	Invalid checksum 139 for command 00 as data 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    Apr-08 12:53:16 PM	 	Warning	No response/improper response from Elk M1 to command 'az00'
    Apr-08 12:53:15 PM	 	Warning	Raw data was: 0100000042 100200000000000000000000000000000 D0000000000000000000000000
    Apr-08 12:53:15 PM	 	Warning	Invalid checksum 199 for command 00 as data 000042 10020000000000000000000000000
    Apr-08 12:53:15 PM	 	Error	Event Front Hall - motion - off action to control a device failed: Object reference not set to an instance of an object
