Hi Mark, I've got an issue with the plugin where it consumes almost 1Gig (yes 1 Gigabyte) of system RAM and will eventually crash the system. Sometimes this will happen after a the system has been running almost a month, but sometimes only after a couple of hours. Attached is a pic of the SysInternals Process Explorer Screen. This also happens on another system of mine that is configured almost identically. Thoughts?
Also, I am trying to get the plugin into debug mode to see if something is going around the time the plugin starts consuming memory, but I'm having no luck. I have the plugin in developer mode but I don't get any X10 DEBUG info in the HS3 log. I've even editing the /config/X10.ini file to PluginDebug=True and restarted the plugin, but no joy there either.
Thanks in advance!
Craig
Below are the specifics of my system:
PC: Asus EeeBox 1.6G Atom w/2GB memory & 120GB SSD
HomeSeer Version: HS3 Pro Edition 3.0.0.318
Operating System: Microsoft Windows XP Professional - Work Station
System Uptime: 0 Days 1 Hour 31 Minutes 38 Seconds
IP Address: 192.168.1.99
Number of Devices: 187
Number of Events: 27
Available Threads: 200
Enabled Plug-Ins
2.0.5.0: BLGarbage
2.0.35.0: BLLAN
2.0.127.0: BLRadar
2.0.91.0: BLRF
3.0.0.75: HSTouch Server
2.17.0.10: MCSSPRINKLERSP
3.1.4.14: SqueezeBox
3.0.0.44: X10
3.0.1.130: Z-Wave
Thanks in advance!
Craig
Enabled Plug-Ins
2.0.5.0: BLGarbage
2.0.35.0: BLLAN
2.0.127.0: BLRadar
2.0.91.0: BLRF
3.0.0.44: X10
3.0.1.130: Z-Wave
