Has anyone experiences the iTunes Plugin failing after iTunes updated to V11?
I had iTunes working when it was iTunes Ver 10. This week iTunes released V11 and I did that update and now I get the following Errors and warnings:
I am using iTunes PlugIn Ver: 2.5.0.13
(iTunes is running before HomeSeer HSPro starts up)
iTunes Error initializing iTunes, either iTunes is not installed or the iTunes Player application is not running.
(Then HSPro start up hangs for a couple minutes before showing the following Warnings)
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Playlist VR has an empty voice recognition phrase (), this phrase is being ignored. Either disable this event for voice recognition or edit the recognition phrase. If using a music plugin, your music library may be empty.
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Genre VR has an empty voice recognition phrase (), this phrase is being ignored. Either disable this event for voice recognition or edit the recognition phrase. If using a music plugin, your music library may be empty.
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Album VR has an empty voice recognition phrase (), this phrase is being ignored. Either disable this event for voice recognition or edit the recognition phrase. If using a music plugin, your music library may be empty.
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Controls VR has a duplicate voice recognition phrase to another event
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Controls VR this event's voice recognition phrase is not active.
12/2/2012 8:38:07 AM Warning Event iTunes iTunes Artist VR has an empty voice recognition phrase (), this phrase is being ignored. Either disable this event for voice recognition or edit the recognition phrase. If using a music plugin, your music library may be empty.
(Then ever couple minutes this Error is repeated.)
12/2/2012 8:40:37 AM iTunes Warning, queued command did not complete due to timeout: player_state
I have looked for any open windows waiting for input that might be hidden and did not find any.
Posting this to see if anyone has seen this and resolved the errors.
Thank You;
Thank You;
