No mention of it at all in the HS logs?
ESP8266 - Proof of Concept
Originally posted by petez69 View PostNick
Just to confirm you made the changes to the UDP library ie: WST reset or you've used a "release candidate" board manager ?
yes I have got my WEMOS connecting to HS...
Pete
Originally posted by NickStrong View PostTried it with both stable and rc.
Just getting this in HS log after it tries to connect:
and then:
I don't have the plugin anymore, but i'll try and modify the sketch later tonight and add some debug info.
A quick note here
It took me a few days to figure this one out.
If you use WiFi then the IP address you use will be stored in flash memory. When you change the IP address in the code and the webserver is starting up it will first look at then stored IP address, not the one you entered in the code resulting in a connection failure, a time out and a watchdog reset. And everything starts over again.
To prevent this from happening add WiFi.persistent(false); before wifi.begin is called or as the first call in setup();- Bram
Send from my Commodore VIC-20
Ashai_Rey____________________________________________________________ ________________
HS3 Pro 3.0.0.534
PIugins: ZMC audio | ZMC VR | ZMC IR | ZMC NDS | RFXcom | AZ scripts | Jon00 Scripts | BLBackup | FritzBox | Z-Wave | mcsMQTT | AK Ikea
Actually i don't use the Arduino plugin at all. I've just used the HS webserver to process incoming data when it's via WiFi. One project uses MQTT. Two other projects are just sending serial data back to the server and a simple callback script is taking care of the processing. It's a tick of me to have control over things and to know how the flow is going.- Bram
HS3 Pro 3.0.0.534
