All,
This is very much beta...I made a lot of underlying changes to correct the fanlinc linking issues. Please backup your hs database and insteon.ini
Fixes:
- Creating links to a Fanlinc will allow setting fan speed (off, low, med, high)
- Inlinelinc with sense On, Off btns restores
- On/Off devices will only get On/Off when creating links.
- Only dimmable devices should get On Level and Ramp Rate options when creating links.
- GetXMLBuffer error (2.0.0.13)
- New Morninglinc device control (2.0.0.38)
Changes:
- Set Filter button is no longer needed on Manage Device page. Just select your filter option and away you go.
Features:
- Added SetDeviceSyncLinkedDevices("aa.bb.cc", true|false) script method to set the "Sync linked responder devices" in case the settings are mysteriously lost (2.0.0.13)
- added support for new On/Off Outlet 2663 (2.0.0.15)
Changes in 2.0.0.26:
- Added a "Reprogram Device" feature. This will reprogram a device with the existing links and settings after manually resetting the device. Important: Make a backup of your insteon.ini before you do this in case something goes wrong. You can revert the ini and restart HS and try again.
- Change On level and ramp rate settings for any link in a device from the Edit Links page: make the changes using the new drop downs and press Update Selected Links
- Added device support for new Range Extender, Morninglinc, and Remotelinc
- Added error blink op flag for KPLs
- Added Reset btn to low battery level device for Hidden door sensors
- A few basic UI improvements
To Install:
1. Shutdown HS
2. Backup your current hs database and insteon.ini
3. Copy all the DLLs in the zip to the homeseer folder
4. Restart HS
please delete and re-add any affect device just to make sure. And recreate other links to control the fanlinc as well
Fixes:
Changes:
Features:
To Install:
1. Shutdown HS
4. Restart HS
