Here are the instructions for installing the EZFlora Plugin.
Please let me know if you have any questions or need any help.
Adam
<!-- / message --><!-- edit note -->
- From the updater download the SimpleHomeNet plugin
- Delete any EZIO devices and shutdown HomeSeer
- Remove any EZIO scripts from the \scripts folder
- Restart Homeseer and the plugin will automatically install
- Within Homeseer, go to the "Setup" tab and then interfaces and enable the SimpleHomeNet plugin and then click save. Upon saving the SimpleHomeNet plugin will become active.
- Click on the "SimpleHomeNet Configuration" link and click on the "Add Device" link.
- Enter the device parameters and click submit.
- When you return to your status page, all devices should be populated.
- The root device will allow you to enable/disable diagnostic mode (cycles through each output in one second intervals).
- Each output can be manually enabled or triggered through use of events.
- Inputs are status only devices (currently on digital inputs are supported). When a status change is detected by the EZIO device, the associated input status will be updated in HomeSeer.
Adam
