The SimpleHomeNet Plugin has been updated to Beta version 1.0.2.0
This version includes the following changes:
Adam
- Added support for SimpleHomeNet EZSnsRF device (I do not own one of these devices to test with. If you have any issues with functionality, please set the logging level to debug and start a new thread in the forum describing the issue and provide the log so I can address the issue.)
- Added support for output timers on the EZIO2X4, EZIO8T, EZIO8SA and EZIO40 devices.
- Output timers are in minutes by default, but can be set to run in seconds on the device configuration page. This change applies to all output timers.
- Output changes that occur as a result of the output timers are not transmitted to the plugin (this is a device limitation). In order to keep the plugin and the device in sync, I recommend setting a resonable polling interval so that plugin will resync during timed polls.
- Changed the add devices screen flow to allow for new features in future updates.
- Shutdown HomeSeer
- Rename the existing HSPI_SimpleHomeNet.dll to HSPI_SimpleHomeNet.bak
- Copy the HSPI_SimpleHomeNet.dll from the attached ZIP file to the HomeSeer directory
- Restart HomeSeer
Adam
