Hi Spud -
Thanks for writing this plugin for Ecobee. I'm excited to get it set up. I tried installing from the HS Installer and get the following error:
Nov-10 11:07:23 AM Error Error, Creating plugin instance: HSPI_Ecobee.exe->Exception has been thrown by the target of an invocation.->HSPI_Ecobee.EcobeeApp
Nov-10 11:07:22 AM Updater Install/Update of package Ecobee was successful.
Nov-10 11:07:22 AM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\\Ecobee.ini
I've read through the forums and found your note about needing to move a couple of files, but that likely that was fixed in newer systems. Mine is a brand new HS SEL and I can confirm that the files are already located in the directory that you specified.
Any other ideas on what I might do to get this working?
Pat
Pat
