Originally posted by spud
View Post
Kodi/XBMC Plug-in - Feature Requests
This is a sticky topic.
Hi
Never mind below. Found all of it. All thou would be nice to have them as buttons in the future. :-)
Using iRule up til now.
But want to use HomeSeer instead. And found your Plugin.
I miss some commands. Is it possible to get them.
Listed below:
StepForward
Step forward 30 seconds in a video.
StepBack
Step back 30 seconds in a video.
BigStepForward
Step forward 10 minutes in video.
BigStepBack
Step back 10 minutes in video.
SmallStepBack
Step back 7 seconds in the current video.
Best regards RonnieLast edited by Baloo69; November 3, 2017, 02:49 PM.
Listed below:
StepForward
StepBack
BigStepForward
BigStepBack
SmallStepBack
Best regards Ronnie
Guest
hi Spud,
I begin with Kodi. I installed osmc on a PI 3b. And i'm tinking about purchasing the vero 4k here: https://osmc.tv/vero/ for the main tv ( my tv can play hdr10 and dolby vision), or wait for a version with 1gb ethernet.
SO...after some research I was able to load plex script and youtube plugin from HS3 events
But is there a way to monitor wich app is actually used on kodi? It would be nice to be able to use that as a trigger. Maybe i missed something.
thanks.
Matt
thanks.
Matt
Guest
Then, would it be possible to create a buttons in Kodi ( like in your exemple) which will open plex script , and send a message at the same time to your plugin?
Originally posted by Summerguy View PostThen, would it be possible to create a buttons in Kodi ( like in your exemple) which will open plex script , and send a message at the same time to your plugin?
even without a button, if you have access to the "plex script", you may also be able to edit it and add a line like this one:
Code:xbmc.executeJSONRPC('{ "jsonrpc": "2.0", "method": "JSONRPC.NotifyAll", "params": {"sender": "Sender", "message": "Message"}, "id": 1 }')
Guest
Originally posted by spud View Postyes that should be possible by doing something like my example
will try this
Guest
Hi Spud,
Is there a way to connect to 127.0.0.1 ? One of my kodi app is on the same Pc as my HS3 machine.
I tried to play with the .ini file .. but the ip adress always come back to 192.168.0.x.
Guest
