Running HS3, xapHub, mcsxap plugin, xapmcsADIOcelot service and connected to an Ocelot via USB/Com 1.
Have a simple program that checks when variable 0 gets set to 1 or reset to 0 and sets variable 3 to 100 or 0 respectively.
In HS 3 when I set the device 6 (variable 0) ON, the light switches on, the command is passed to the Ocelot as witnessed directly on the Ocelot and the Variable 3 is set to 100 as witnessed both in the Ocelot and the xapmcsADIOcelot browser but it is not reflected in HS. On the xFx viewer 4, I see the outgoing command but no incoming messages for status. So either xapmcsADIOcelot is not reporting the status, or mcsxap plugin is not asking.
