Hello,
I changed my station yesterday. A new fanless PC instead of the old one.
Everything went ok about Homeseer and Z-Wave plugin, using export/import config. Easy, quick, simple. Not any shadow in the process.
About Jowihue, well that's not the same kind of thing.
There's now not any sensor or switch anymore. I got new lights and I was obliged to erase old ones and rename new ones. I got most of my sensor appearing in deCONZ (but all my names disappeared), but none in webapp, Phoscon, nor Jowihue.
I don't understand. Who owns the database here ? Jowihue as I thought ??? Or deCONZ ? or anything else ?
Why things did get great with the Z-wave plugin, but not with Jowihue ?
Should I have saved some configuration file into deCONZ before changing my hardware ?
Why isn't it written somewhere that things can go wrong in such a case, some kind of warning before people change their computer ?
Please, if someone here has an idea about this issue, well he will got my eternal devotion.
Thank you,
Michel
EDIT : I imported again the config. Of course both all my sensors and switches came back. But not anymore in deCONZ, even not the lights that had come back the first time.
And if I trun off/turn on Jowihue, then, and this is the precise moment where it happens, all the sensors and switches have disappeared.
Thank you,
Michel
