Is there any plan for the WD100+ firmware to ever support a mode similar to the WD200+ where the dim level LEDs only show when changing the dim level locally? (So not necessarily supporting status control of each LED, just ability to have them all off when not changing dim level).
I've got a bank of dimmers, three are WD100+ and one a WD200+ in status mode which only shows the DIM level when I'm operating the switch locally. I really like this feature and would prefer the same to apply to the other 3 WD100's in that box. In this case, I don't need the RGB, multi-tap 4/5, or status functionality on the WD100's, but much prefer the look of no LEDs active except for LEDs showing status. Just recently upgraded to the WD100's for these switches, so not thrilled with the idea of replacing all with WD200's.
Thanks.
(BTW - very happy with the WD200+ - already finding being able to show status of things on the bedroom dimmer very helpful).
Thanks.
