Screens created with HSTouch
    Here are a couple shots of the screens I have been working on. I am by no means a designer, nor know anything about graphics, so its not perfect. I will say one thing i keep in mind when making the screens, I stick to keeping no more than 2 clicks on the screen to get to what I need. This has helped a lot with the WAF which has to remain high in order for me to keep my addiction going.
    I have the temps setup to rotate every 5 seconds between outside and inside temp, and also I try to keep things readable from roughly 10 feet away. I have a few panels around the house, but keep separate projects for each panel in designer. They design is the same across all of them to maintain uniformity, but things like music do different things for each room when controlling the audio. Lights are also different for each room.
      Nice work waynehead99! What's the traffic light for and could you post a pic of your lights screen.
      Sent from my iPhone
      Tom
        Some of my IPHONE Screens in hstouch
        Here are some screens from my Iphone HSTouch project
        Regards Bart
        Win7 64Bit on Intel NUCI7 with SSD
        HSPRO 3.
        Devices; 1370 Events; 691
        Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
        Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
          This is one of my favorite Threads, I always like to see what others are creating with HSTouch. So I think it is time to share mine to.
          I am not a graphical designer and it is not overloaded with al kind of cool features but it does the job.
          By the way, Bart I really like your Iphone screens! looks very professional.
          greetzz
          Martijn.
            Looks good. Could you show how you are displaying the LMS (Logitech Media Server)?
            DSteiNeuro
            HS3Pro
            Enabled Plug-Ins
              Nice Job Martijn! It certainly does the job. Like the squeezebox integration.
              Tom
                Ofcource!
                Nothing fancy about it, its just a textbox.
                See the screenshot below:
                  new 17" touch screen added to my man cave.
                    Very nice screens! I used to have elaborate screens back in HS2 days, just haven't found the free 10,000 hours needed to make something like that since
                    Mike
                      i wish i was more of an artist, i would love to use completely home made screens, but its just not in me
                        Any ideas or direction on how to populate an HSTouch screen with a Google Maps traffic layer image? I could have swore I saw a pic posted where someone had done this but I can't seem to find it now. Anyone successfully done this?
                          I'm not sure of the legalities so I'm not being too descriptive but have a look here https://developers.google.com/maps/d.../layer-traffic
                          If it's just a single location that you're interested in, then you can create an html file, save it in your HS3 html folder. Add a text element to hstouch and set its text element to the url of the saved html file and set the ishtml property to true.
                          Of course you could have multiple html files with different settings or use a script to generate the file dynamically.
                          Paul..
                            I have a traffic page using google traffic maps.
                            just went to the location I wanted, turned on traffic, and copied the URL into HS Touch in a text box.
                              Thanks for the tip! I did as suggested and inserted a text element and pasted in the URL to a google maps search. I set is HTML to true and allow navigation to true. The page shows up but I receive a google page advising my browser is unsupported instead of the search result that the link should direct to. Did you run into this issue?
                                No, didn't have that, but that is probably because of the changes I made. See this thread. http://board.homeseer.com/showthread.php?t=176505 Homeseer defaults to IE7. That thread shows how to change it.
