Originally posted by heatvent
View Post
New Status Icons!
Originally posted by Rupp View PostHopefully the plugin authors are testing their plugins with the new betas as much has changed. You may want to mention this issue with these plugin owners in case they did not see the release notes or see this thread.Plug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Mark,
I am a bit disappointed to see HomeSeer 2.4 was released without any type of communication to HomeSeer developers. The status icon change is what is causing me the most grief. The 16 x 16 gif icons I include in all my plug-ins look terrible in HomeSeer 2.4 and I see no way to change it back to 16 x 16 without having to edit the settings.ini.
When you get a moment, can you answer the following questions?
- There are 3 ways to display status icons. Using graphic/values, devicestring using an HTML img tag or letting HomeSeer figure out if an image exists matching the devicestring. Does HomeSeer 2.4 adjust the images height and width in all cases? If not, when does HomeSeer automatically adjust the status icon image size?
- When using HomeSeer device graphics/values, do I configure the HomeSeer devices to use the .png icons or should I just rename the .png icons to .gif?
- When using the HTML img tag within the HomeSeer DeviceString, do I need to include the height and width attribute?
- If I provide 32 x 32 icons with my plug-ins, how do I need to configure the status icon to make sure it displays 16x16 in HomeSeer 2.3?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
I notice that on the device page there is a facility to "Edit Value Statis / Graphic Pairs" which I presume allows you to select the graphics you with to associate to that device.
I presume for the graphic file you have to type in the full path to the picture for each value. Could someone remind me what the value's are for on off and dimmed.sigpic
Originally posted by Mark42 View Post<<facility to "Edit Value Statis / Graphic Pairs" >>
I have a similar issue, but I am unable to find the edit faciilty you are refering to. How does one navigate to this screen?
Best Regards,
Marksigpic
Originally posted by ve3bwp View PostI see the new Icons after the upgrade.. dumb question.. how do you change them. All of my devices still show just the (newer) bulb icon. Is there a setting option to assign a new icon to a given device?
vegascat
9/21/2009 Edit. I've attached the new icons to this post. Just backup your existing icons first and then unzip HS-New-Icons.zip and copy the icons into that folder.[/quote]
What happened to the motion icon? I have seen the others, but not that one with my X10 motion detector.
icon status change
Hi
Ive placed the script" hs.setDevicestring "D2", "<img src=no motion.gif>"in the edit value status/graphic pairs under display status then placed the path of the graphic in the graphics file but still no icon. It just takes away the bulb and on off buttons Can you tell me what im doing wrong. Also how do you make one for off and one for on. im using HSPRO
John
