I am upgrading HS2 > HS3 and moving from Dell D600 / WinXP to a newer W7/8.1 laptop that does not have a COM port.
I read the forum and see that it is recommended to stick with EdgePort USB to serial products as they are seems to be the most reliable.
But ... what if I connect my TEMP08 with this adapter to my laptop via an USB hub? The HUB would have three other devices connected to it including a Z-Wave stick, an external hard drive and a webcam.
Do you think the system will still be relivable with this daisy-chain or should I search for a laptop with more USB ports instead?
Thank you.
Thank you.
