Http trigger
    Http trigger
    What is the easiest way to have a button hit a url such as: http://10.0.0.240/IR.php?device=tv1&...samsungTVPower
    Add an action to a button, click run a script with values from elements. In the middle box for the script name put in
    &hs.geturl("http://10.0.0.240/IR.php?device=tv1&...samsungTVPower","", True, 80)
    And see if it works, whilst it may work it is not necessarily the best method. The moment your IP address changes or the code changes you will be cursing when you have to open the designer, change it, redeploy the client etc.
