Originally posted by Rotech
View Post
PHLocation V1 Release Notes [No longer in development]
Configuration info for EgiGeoZone tracking
Once you have the plug-in up and running, go to Plug-Ins>PHLocation>Users/Devices and add a new user of type Egi (Tracking). Don't forget to configure the options on the PHL tab, set the user as active and hit the save button.
You will need the DeviceRef number for the root user device you just created. If you hover your mouse over the device name of the root device you will see the text ref=xxxx where xxxx is the number you need.
The rest of the config is done on the EGI app.
Open one of your fences in the mobile app then hit the Location Tracker Settings option. Have a look here for a description of the settings http://www.egigeozone.de/manual/defa....html#Tracking
Leave write tracks to local file un-checked.
In the URL for tracking enter exactly as below replacing xxxx with the DeviceRef obtained earlier.
http://<yourhs3server>:<phlport>/phlegitracking?androidid=${androidId}&lat=${latitude}&lon=${ longitude}&acc=${accuracy}&date=${date}&phlid=xxxx
Originally posted by Rotech View PostWhere do I get ver 36 of the plugin?
http://board.homeseer.com/showthread.php?t=162373
The link is in the post.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
I forgot how to place the files. One goes in the HS3 root (the txt one), but where does the one goes?Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
I think I have it working, Iam getting data to the devices. only thing strange is that the street address and town are in German.... is there anything else I need to change?Hector
Win.2003 OS, HS3
Originally posted by Rotech View PostI think I have it working, Iam getting data to the devices. only thing strange is that the street address and town are in German.... is there anything else I need to change?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
1- You haven't actually moved you Android device since installing, but instead you've hit 'test' on your Android app profile: that will always return the EgiGeoZone author's coordinates somewhere in Germany; once you move your Android device, you'll start getting your location
2- you haven't entered your coordinates (long, lat) on your Android app fence: hitting the square with a map in it will GPS your current location and use those coordinates; I think they are by default the Author's.
Hi Paul ,
I updated to the last version but i get Some errors , what do i need to do?
Regards
Sended from far far awayPreferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
