Hi - Periodically, two of my EZFlora 8-zone Irrigation Controllers, Model #5010A, have shown some unreliability. The symptoms range from not turning on or off as scheduled.
In looking at the logs, I noted error messages "Error transmitting message to get valve status..." for two of the controllers. What is the cause of this? How do I debug this problem? Or better yet, is this issue indicative of something I should do to fix the problem?
In the attachments, I have included a copy of the EZFlora.ini file as well as selections from the HS3 log file.
Please note in the log file that on the startup of HS3 and the initialization process, it would appear (to me, at least) that the Insteon plug-in is attempting to communicate with the EZFlora controllers also, when that task should be exclusively done by the EZFlora plug-in. If I am correct here, is this an issue that I should be worried about? If so, how can I fix it?
Finally, I still have HS2 Pro running in parallel with HS3. However, I have deleted all of the EZFlora controllers from the HS2 installation. But, the HS2, EZFlora is still installed.
Thanks for your help.
