The plug-in has been working great for months. I recently upgraded to .298 and then to .307 of HS3. I am not sure how long this has not been working but maybe was ok in .298. I am running V 3.4.1.0 of the plugin.
The issue is: I use a motion sensor to trigger lights on in my furnace room when I enter. The sensor is type 25 for "chime only" as I want it to fault but not trigger an alarm. This is the only one that has this problem and there are other type 25s in the mix.
If I do a Get Zone Info it shows up in the list as Zone 4 "FURNACE MOTION". It exists in the INI file as the same.
4 FURNACE MOTION 25-Chime Only
Zone1-Name=Zone 1
Zone2-Name=Zone 2
Zone3-Name=HALLWAY MOTION
Zone4-Name=FURNACE MOTION <<<<<<<
Zone5-Name=BSMT HALL MOTION
Zone6-Name=WORKSHOP MOTION
Zone1-Type=3-Entry/Exit Delay 1
Zone2-Type=5-Motion Sensor
Zone3-Type=5-Motion Sensor
Zone4-Type=25-Chime Only <<<<<<
Zone5-Type=5-Motion Sensor
Zone6-Type=5-Motion Sensor
[Zones]
Scan_YN_Zone1_checked=0
Scan_YN_Zone2_checked=0
Scan_YN_Zone3_checked=1
Scan_YN_Zone4_checked=1 <<<<
Scan_YN_Zone5_checked=1
HS_Device_YN_Zone3_checked=1
HS_Device_YN_Zone3_Ref=1439
HS_Device_YN_Zone4_checked=1
HS_Device_YN_Zone4_Ref=1366 <<<<<
HS_Device_YN_Zone5_checked=1
HS_Device_YN_Zone5_Ref=1440
When I run the Create HS devices, all zones appear except Zone 4. It should appear after FRONT DOOR in the list
1459 Normal Caddx FITNESS WINDOW Today 3:27:28 PM
1444 Normal Caddx FRONT DOOR Today 3:27:33 PM
1464 Normal Caddx GAR REAR DOOR Today 3:27:29 PM
I have tried disabling and reenabling the plugin. I have done a disconnect and reconnect to the panel.
Looking for suggestions on how to get Zone 4 into a usable device.
Zone1-Name=Zone 1
Zone2-Name=Zone 2
[Zones]
