Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer General Discussion Area
HomeSeer General Discussion Area General discussion about HomeSeer that does not fall into any other category or are not specific to 1.x or 2.x versions of HomeSeer.
Old August 12th, 2017, 04:12 PM
jono jono is offline
Seer Master
Unifi Controller Wifi user connect/disconnect data
The Unifi Controller is wifi access point software that logs events, for example who has connected or disconnected to a home network. I would think this could be useful to import into HS3. Then you would have data as to who is at a house and when based on their devices connecting to wifi.
The trouble is that the data is not readily exported to syslog. It can be monitored on a webpage and can also be accessed by SSH using the command tail -f /var/log/messages
but that just gets the data into a command window.
I was hoping to get it into a text file where a log monitor could translate it into HS3.
I'm getting out over my skiis so thought I would ask this community if anyone has found a way to get the "event" data (i.e. Jim's iphone has connected) from Unifi into HS3.
Old August 12th, 2017, 05:05 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Here been mapping a shared drive to the Homeseer Pro data directory for logging. IE: /HomeSeer/data/sharedirectoryname
IE: for lightning it's just a lightning directory with the logs (not written currently to /var/log directory rather it is written to the /opt/lightning/log directory).
Just share (use Samba) the log read only file then map the share on your Homeseer machine (well if Linux) using fstab.
1 - configure the SAMBA share directory in the the /etc/samba/smb.conf file
[ICS-Znet] ;the share name can be what ever you want
browseable = yes
path = /opt/digitemp
guest ok = yes
read only = no
create mask = 777 * or 660 if this bugs you.
2 - configure the mapping in FSTAB like so.
# One Wire Share
//192.168.244.169/ICS-Znet /HomeSeer/Data/1-wire cifs guest,uid=1000,iochars$
3 - test it by remounting all.
I used to do an ssh copy which really is a pita.
If you are running Homeseer in Windows you can do the same.
Thinking Jon00 has a plugin / script that will will help you with said endeavor.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.4449
Old August 12th, 2017, 06:55 PM
vasrc's Avatar
vasrc vasrc is offline
Seer Master
I've wanted to try this for awhile now but the Unifi SNMP doesn't list users (they're on the controller and SNMP looks at the individual AP devices) so I never attempted it. There is however a PHP class that does retrieve a LOT of info. There's also a Unifi Browser, (https://github.com/malle-pietje/UniFi-API-browser) where you can view the data stored on the controller.
If you have PHP running, it should be a simple matter of retrieving the JSON data from the API class and then exporting it to HS3. I may have to look at it again as I had the same thought about using it to watch devices come and go from the property.
Z
Old August 12th, 2017, 07:20 PM
Seer Master
Z
Thanks Z. I have 3 AP devices in my house, so was hoping there would be a way to get the devices coming/going from all 3. That is why the controller software is so frustrating. The info is all in the central controller, but just can't get it out. There may be a way to do it using a screen scraper on the web pages from port 8443, but it seems like that would be a pretty kludged workaround.
Strangely, Unifi doesn't make the event database available, even though it would be incredibly useful to make it available.
Please let me know if you decide to work on this. I'd be eager to help, though my skills are limited.
Old August 12th, 2017, 07:26 PM
Seer Master
browseable = yes
guest ok = yes
read only = no
# One Wire Share
Hi Pete, thanks for your reply. Unifi Customer Support told me that the file that includes the events is encrypted and therefore no use to me. So they suggested the SSH method, which I got up and running in a command window, but that was at the outer limits of my capabilities. I apologize but much of your post seems to be beyond what I might be able to do.
Old August 12th, 2017, 07:33 PM
vasrc's Avatar
Seer Master
There is an JSON API you can use to retrieve BUT it requires a prior login, so it's not a simple one liner. There are several PHP examples, but you could easily do a VB/C .NET using HttpWebRequest.
Try this and you'll see the events (which contain Connect/Disconnect)
https://UnifiControllerIP:8443/api/s.../list/wlanconf
JavaScriptSerializereserialize should be able to stick it in an array for you.
Z
Old August 12th, 2017, 07:40 PM
vasrc's Avatar
Seer Master
Z
Oops wrong URL, https://IP:8443/api/s/default/stat/event)
Z
Old August 12th, 2017, 07:52 PM
Seer Master
I get this:
{ "data" : [ ] , "meta" : { "msg" : "api.err.LoginRequired" , "rc" : "error"}}
Not sure what it means, but may need a username/p.w. in the url
Old August 12th, 2017, 07:55 PM
vasrc's Avatar
Seer Master
I get this:
Yup.. Just for grins, try logging into the controller from the same browser your' entering the URL. See if that works. I can get it to respond but I also have the PHP code running in the background.
Z
Old August 12th, 2017, 08:13 PM
Seer Master
Z
I did log in on a different tab of the same (chrome) browser. Same response.
I'm not sure what the PHP code running in the background is, but is that easy to set up?
Old August 12th, 2017, 08:48 PM
vasrc's Avatar
Seer Master
You need to have a device that can execute the PHP server code (I just use one of my Synology NAS boxes). You can also install it on your PC if you'd like.
Looking at the data, they pretty much show everything possible from the Unifi Controller, not just events.
Z
Old August 12th, 2017, 09:48 PM
S-F's Avatar
S-F S-F is online now
OverSeer
I use UltraLog to determine which Unifi AP people are connected to. I send the Unifi logs to the UltraLog syslog server. Painless and works a treat especial. For example HS knows I'm outside right now so all TTS will be routed to the yard speakers.
Quote:
Originally Posted by rprade View Post
Old August 12th, 2017, 10:41 PM
vasrc's Avatar
Seer Master
Quote:
That's way too easy
Are you remote syslogging the logs?
Z
Old August 12th, 2017, 11:36 PM
S-F's Avatar
OverSeer
That's way too easy
Z
Not sure what you mean by "remote syslogging". I'm sure it makes sense to people who know what's going on but..... I ask that you keep in mind the fact that I'm only one or two IQ points away from removing tattoos with sand paper and the next step from smearing poop on the walls crazy. The controller and HS are running on the same machine but I don't think that makes one lick of difference. As an aside UltraLog saves all of the logs from my Unifi APs. I now have years of logs saved from both HS and Unifi by UltraLog that I can search. Pretty nifty right there.
Old August 12th, 2017, 11:44 PM
vasrc's Avatar
Seer Master
Actually it does (the running on the same machine)
my controller is on a Unifi cloud key (standalone device about the size of a carton of cigarettes) so there are no local files to access. Remote syslogging is just an old unix process that lets you log to another computer
Z
  #16
Old August 13th, 2017, 07:21 AM
S-F's Avatar
OverSeer
Z
Gotcha. It doesn't matter as long as it's all on the same network. The logs aren't generated by the controller. They com from the APs themselves. Just like most things Unifi this works when the controller is down. You use the controller to point the logs from the APs to the HS machine. I often don't have the controller running. One of the options for event triggers with UltraLog is the source IP. When I get a log from the outside AP saying that the MAC of my phone has connected I run an event.
  #17
Old August 13th, 2017, 08:00 AM
vasrc's Avatar
Seer Master
I guess that's the part I'm missing. How are you actually getting the logs from the AP's (or controller for that matter) to your PC?
Also, what text are you parsing for? There's a ton of data sent in the logs..
Z
  #18
Old August 13th, 2017, 09:27 AM
S-F's Avatar
OverSeer
In the Unifi controller you select use a syslog server or whatever and give it the ip address and syslog port of your HS machine. The APs then start sending logs and you can shut down the Unifi controller. For UltraLog events I look for a line indicating that a certain phones MAC has connected or disconnected and I also look for a unique identifier for the specific AP I'm wanting to work with. I just looked at the syslog output in UltraLog to figure out what meant what.
  #19
Old August 13th, 2017, 09:32 AM
Seer Master
Mine is now working! The key was to use the ip address of the access point for syslog entries. I was using the ip address of the computer that was running the controller software. My syslog software is Kiwi and it requires one to enter the ip address of the source that the syslog files are coming from.
Now that I have the APs logging, I can use mac address to know when someone is at my house or not, or even to do geolocating within my house. I have BLLogmonitor scan the syslog files for the mac address and turn on virtual variables representing presence or absence.
Thank you all for helping me out!
  #20
Old August 13th, 2017, 09:38 AM
vasrc's Avatar
Seer Master
Ahh... Remote syslogging
Do you ever have problems when your device "moves" to another AP? I'm assuming you'll get a disconnect then?
Z
HTML code is Off
Adding Serial Connect and Disconnect Actions travisdh HS3 Plug-In Development 2 April 16th, 2014 03:47 AM
HSTouch Client connect - disconnect Ken LaCapria HSTouch™ 1 September 3rd, 2013 06:33 AM
How to force disconnect and ask on connect? msbreton Clients - Apple iPhone/iPod/iPad 4 February 3rd, 2011 07:47 PM
User data not loading - shows as Unknown user dmronning UltraM1G HSPI 3 September 16th, 2008 06:48 PM
Speaker Client connect/disconnect issues... surovich HS2 / HSPRO 2 February 13th, 2006 07:46 PM
