I just purchased an ab8ss and cannot find any information on connecting the 2 inputs on the unit.
I have a technics AV receiver for one of the inputs and want to use my homeseer pc for the other input. Should I just connect the pc audio out to the CD channel in on the receiver and then just use the receiver for both inputs.
How do you wire the inputs on the AB8ss unit?
Do you just use an Audio out from the AMP using standard RCA jacks and then cut the other ends to wire into the inputs on the AB8ss unit?
What is the best method to use for the switching of speakers?
Input selection can be made by Infrared remote control, X-10 command (TW-523 required) or direct serial commands (sample QBASIC program).
Can the TW-523 be used with no custom programming to control the ab8ss for homeseer?
