Insteon Lighting Plug-In v1.3 with Motion Sensor and Triggerlinc Support
    #31
    Thank You!!
    -ron
      #32
      Hello,
      I have v5.0 Icon 2876DB switches which I received from Smarthome as warranty replacements. Even with this latest plugin, I receive the following message: "Unknown Device Type 011E", if I manually add them.
      When I try to swap out my old devices, I receive a message that they are not compatible.
      Is there something that I can update, or do I have to wait for the next revision?
      Greg
        #33
        You can't swap unlike devices. And I'll need to add the new devtype to The next rel
        Mark
        HS3 Pro 4.2.19.5
          #34
          I guess that the dev/cat type changed based on the new switch revision. Do you have any idea when I could expect a new release.
          Thank you very much for your work with this.
          I really don't like the idea of going with the ISY and would like to stay local.
          Greg
            #35
            Greg
            Greg, post a msg on my visitor page with your email and tonight i will send you an intermediate build to support the new device.
            Mark
            HS3 Pro 4.2.19.5
              #36
              Mark:
              Since you have sort of a relationship now with Smarthome, how come they can't give you the information that you need in advance on any new item? This way you can update the code without someone telling you they have a new item.
              Just a thought.
              Steve
                #37
                Originally posted by skozin View Post
                Mark:
                Just a thought.
                Steve
                I have access to their beta product xml file (associated with houselinc) but have not spent a lot of time looking for the "new" items. The main reason is i am still playing catchup on products that are already on the market
                Mark
                HS3 Pro 4.2.19.5
                  #38
                  Well keep up the great work. My system has been running without any problems since you took over the plugin.
                  Thanks again for all the awesome programming!!!!!
                    #39
                    Is there any way i can get the intermediate build i also have the same issue wih my Icon 2876DB switches being reconized as Unknown Device Type 011E.
                    Thanks.
                      #40
                      Thanks.
                      please post a request to my visitor page with your email and what version (plm or plc) you need
                      Mark
                      HS3 Pro 4.2.19.5
                        #41
                        Confirmed problem(s) with 1.3
                        I was using 1.3 since the day you released it and having all sorts of issues.
                        I'd notice that sometime after starting HS 'looked' like everything was working (logged all incoming and outgoing) but the lights never responded. I suspect that the plugin was not sending the signal to the devices.
                        Then I tried tap-add my ApplianceLinc. It would see the address but could never program it... no matter where in the home I put it.
                        Then I noticed that HS hung on shutdown, at the Insteon line in the log, every time. I had to kill the process. I verified this 5 times.
                        Tonight I went back to 1.2.3.4 and all is well again, no problems - it programmed my ApplianceLinc and all is well.
                        There is definitely an issue or 2 with 1.3
                          #42
                          Aaron,
                          I need a little more info. I'll check on the shutdown issue.
                          did you every try manually adding the applinc? please post the ini section for the appl linc.
                          which interface are using plc or plm?
                          Mark
                          HS3 Pro 4.2.19.5
                            #43
                            Yes. It makes no difference... adding was fine, event tap-add worked. BUT reading the link and programming for homeseer never worked, It never connects to the device, only keeps making attempts.
                            PLM
                            - once I moved back to 1.2.3.4, not a single issue.
                              #44
                              PLM
                              could you post the ini section for the device in question and
                              do you have any debug logs of the link reading session you could post?
                              i have the following appliancelinc and everything seems to work. is yours different?
                              DeviceType=0209
                              FirmwareVer=32
                              Protocol=2
                              Mark
                              HS3 Pro 4.2.19.5
                                #45
                                DeviceType=0209
                                FirmwareVer=32
                                Protocol=2
                                no log but here's the config...
                                GroupLinkAddress 1=8
                                GroupLinkAddress 2=9
                                GroupLinkAddress 3=10
                                GroupLinkAddress 4=11
                                GroupLinkAddress 5=12
                                GroupLinkAddress 6=13
                                ChannelName6=
                                NoChannelSync=0
                                DeviceID=01.03.CC
                                DeviceName=Espresso Machine
                                DeviceLocation=Kitchen
                                PollingInterval=10
                                DeviceType=0209
                                FirmwareVer=23
                                DatabaseDelta=3
                                LinksDownloaded=1
                                Protocol=1
                                EEValues=
                                LastContact=2/26/2010 8:13:36 PM
                                TotalInteractions=128
                                FailedInteractions=0
                                NumLinks=3
                                Link 1=A2 FE 0C A7 33 FF 1F 01 1
                                Link 2=A2 03 09 9B 07 FF 1F 01 2
                                Link 3=A2 01 0C A7 33 FE 1F 00 3
                                RecentDatabaseDelta=3
