Recently I started to experience problems with the plugwise pro plugin. After a reboot of the PC the com port of the plugwise stick is closed, and can't be accessed by the plugin. After a disconnect and connect of the stick the problem is solved. As far as I can tell the problem started about a month ago...
Are there other people having this same problem?
