You made some good points and perspective that should make this plugin more friendly for new users. Thank You for taking the time to help make it better.
I notice when I am in VS at breakpoint I will sometimes loose the broker and need to restart the plugin. There is logic to reconnect, but really have not exercised it nor have I looked at the Tasmota code to see what it does since I know my Sonoffs often reconnect.
I am still bothered by the dynamic page update with divToUpdate that I cannot get to work. It would be so much better to see the additional setup options when a selection is made rather than needing to rebuild the entire page. Seems nobody on the board has run into a problem in this area as no response to my post asking for suggestions.
The debug should be an easy fix.
