cant find devices
    cant find devices
    I cant seen to scan for any devices. Here is my error message.
    Mar-17 00:18:56 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: HARMONY COMMUNICATION LOGIN : FAILURE ERROR : connectToHarmony : Unable to connect to specified IP Address on specified Port -
    Mar-17 00:18:35 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Mar-17 00:18:25 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: HARMONY COMMUNICATION LOGIN : FAILURE ERROR : connectToHarmony : Unable to connect to specified IP Address on specified Port -
    Mar-17 00:18:04 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    thanks
    thanks
    These kind of errors, is in most cases because or wrong ip adres, firewalls, or other network issues.
    Please check firewalls and network settings.
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
