I just installed plug, started off with perimeter mode, got devices in, but I think Aim missing something, when the one is tripped, it does not announce the area where it was tripped, anybody seen this before?
Trying out blsecurity
There's no reason you can't use that "alert" as a trigger to announce the opening though.
BTW Hector, didn't i read somewhere on here the you had installed a DSC system? If so I guess i wonder why both, or did you change your mind on the DSC?Marty
Originally posted by nightwalker View PostThere's no reason you can't use that "alert" as a trigger to announce the opening though.
No I havent changed my mine, I use DSC for the hole house sistem, but I would like something that can monitor the outside peremiter and alert me with a TTS in my room, not with a alarm..Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by TrOjAn View PostI think you are expecting a lot more from this plugin than it actually does.. it doesnt announce the area that was tripped..
If a perimeter sensor is tripped thats it, the perimeter is in alert,
TrOjAnHector
Win.2003 OS, HS3
